Not sure if anyone is using this tool or not. It's the Remote Admin suite which basically allows you to run Systems Manager/Report Write/MapMaker, etc. from your machine. The applications basically connects to the server's DB and allows you to make changes without having to log locally to the server.
I've tried on both XP and 2000 to get this to work and I'm not having luck. I run the configuration wizard and it connects to the server DB without any problems.
Once I tried to run Systems Manager it says its connecting to the polling engine and then I get an error :
NetPerfMon
Cannot connect to XXXXXX (server name here)
Everything from an SQL perspective looks fine. I can run SQL Manager and connect and query the DB.
The version of the tool is V7.0.140 December 2003
Anyone have run into this or have it working? Thanks
