cancel
Showing results for
Search instead for
Did you mean:
Create Post
Problem Adding Cisco Switch 9200 to NPM using SNMPv3
When adding the node through SNMPv3 the test connection tests successfully but when I hit next it times out and the error  "currently down, unreachable, or provided credentials are not valid"
I have verified:
The connection is established
Traffic is permited
The switch configs are correct
The crednetials are correct
Attached is the snmpwalk
0 Kudos
This is the switch config
snmp-server group GROUP_SNMPV3 v3 priv access SolarWinds_SNMP
snmp-server trap-source GigabitEthernet0/0
snmp-server source-interface informs GigabitEthernet0/0
snmp-server location Bldg1_Room1
snmp-server host 192.168.100.100 vrf Mgmt-vrf informs version 3 priv SW_User_v3
0 Kudos
I'm not seeing an "snmp-server user" line in your config.
You should create a user and make them a member of the group you already have
0 Kudos
Second this. Also check your firewall to validate it is passing traffic.
0 Kudos
Sorry I did not include the snmp-server user, but this was created.  It doesnt show in when you do a show config but you can do show snmp user and I confirmed it is there.
0 Kudos
In that case, the only other thing I dont see in your config is an "snmp-server view" line.
Here is how our 9200 configs look:
snmp-server view VIEWNAME iso included
snmp-server group GROUPNAME v3 priv read VIEWNAME
snmp-server user SOLARWINDSUSER GROUPNAME v3 auth sha password priv des password
then in SolarWinds:
0 Kudos
