cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 10
Polling Engine Status?
Jump to solution
How do I improve this or is it something that needs improvement? Here is what mine says:
Last Database Update   7 second(s) ago
Polling Engine on   SOLARWINDS
IP Address     192.168.xx.xx
Last Database Sync     16 second(s) ago
Network Elements     104 Nodes, 860 Interfaces, 90 Volumes, 1054 Total Elements
Polling Completion     100.00%
Software Version     Windows Server 2016
Service Pack
What would you fix first? Do I need to manage my Pollers? Turn off the ones Im not using?
Just learning how to keep my system as good as it can be...
Thanks-
Nato
Tags (1)
0 Kudos
1 Solution
Level 16
That isn't capacity, it means of all the elements you are polling it is completing the job 100%. When that number drops down to less than 100 it means its not keeping up.
Your system looks healthy to me.
Level 10
So I take it- this is not a problem- even though it says a near 100% capacity...
0 Kudos
Level 16
Level 10
Ok- Thanks for clearing that up for me- I do appreciate it! Nato
0 Kudos
Level 9
Looks totally fine, do you experience performance issues or something else?
Level 10
No I dont- I was just doing some checks on it and thought it needed attention- but now I know - this is normal. Thanks- nato
0 Kudos
Level 16
That looks pretty normal in comparison to mine
Agreed, there's nothing in this short post that indicates anything needs to be tweaked.
