cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 7
Orion Network Atlas - Generate Heat Map Problem/Question
Greetings All,
I am trying to Generate a Heat Map so we can map the wireless coverage for our floors in our building.  I have set the background image to the floor plan, I have set the map scale, and I have placed 9 managed wireless access points on the map.  When I try to generate the heat map, it says I am missing a step necessary even though I have addressed everything required.
Does anybody have any ideas?
I have attached a picture for reference.
Thank you in advance.
0 Kudos
Highlighted
Level 13
Re: Orion Network Atlas - Generate Heat Map Problem/Question
Are all your nodes Cisco devices? WLHM currently only works for those type of device, apparently.
0 Kudos
Highlighted
Level 7
Hi janene16,
Thank you for your response.  Yes, all of our Nodes are Cisco devices.
0 Kudos
