cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Orion NPM v8 Hot-Standby Engine
Would Orion NPM v8 Hot-Standby Engine work with NPM version 9? Or do I need to upgrade it as well?
Thank you,
0 Kudos
Level 19
HSE 8.x is not compatible.  You must upgrade everything to v9 or it won't work.
0 Kudos
Level 7
Thank you Denny for your prompt reply.
Any issues with APM v1 - ALX? Would this work with NPM v 9?
 - aelrayah
0 Kudos
Level 19
Orion 9 is compatible with:
APM v1 SP3 or later
NTA 2.2.1
VoIP 2.0 SP1
Wireless 8.5
0 Kudos
