cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Open Maps in same window.
A change from 9.1 to 9.5... now clicking on a nested map causes the map to come up in a new window (or a new tab if running firefox).  I'd rather have submaps open in the same window.  Is there a way to do this in maps being shown by mapview.aspx?
0 Kudos
Level 7
I would like this function fixed as well. Having a massive amount of webpages open is not functional as well as very hard ot figure out which one is the real site and which ones are the opened window.
0 Kudos
Product Manager
Product Manager
We are looking to address in an upcoming SP
0 Kudos
Level 10
I would like to resurrect this thread. It does not appear that this made it into SP1. Do we know if this will be in SP2?
I am waiting on making the jump to 9.5, due to this functionality.
0 Kudos
Level 7
They fixed it in SP1
Wayne
0 Kudos
Product Manager
Product Manager
Are you sure, this should be addressed with SP1.  What behavior are you seeing?
0 Kudos
Level 10
Oh, I have not upgraded to 9.5 yet. I was going to wait for this to be fixed, and I did not see it in the SP1 patch notes. Did I just miss it?
0 Kudos
Product Manager
Product Manager
Hmm, might have just missed that in the release notes, I looked in our defect tracking system and it should be fixed with SP1, I will look at getting the release notes updated
0 Kudos
Level 7
I didn't see it either but it *is* fixed.. at least it fixed the issue for me.
0 Kudos
Product Manager
Product Manager
I am not sure if there is a workaround, but that is a documented defect in 9.5
0 Kudos
