Hello Experts,
Trying for fresh install of NPM 12.3 with standalone and with default database. At the configuration Wizard, facing below error. Any help here please?
2020-03-26 18:42:32,737 [11] DEBUG DependencyAnalyzer - Found 1 matching packages
2020-03-26 18:42:32,738 [11] DEBUG DependencyAnalyzer - Orion.AgentManagement [2.0.0.592,]
2020-03-26 18:42:32,739 [11] WARN DependencyAnalyzer - No packages of type Orion.AgentManagement found!!!
2020-03-26 18:42:32,740 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.AgentManagement [2.0.0.592,]
2020-03-26 18:42:32,741 [11] DEBUG DependencyAnalyzer - Orion.RecommendationEngine [1.2.0.211,]
2020-03-26 18:42:32,742 [11] WARN DependencyAnalyzer - No packages of type Orion.RecommendationEngine found!!!
2020-03-26 18:42:32,742 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.RecommendationEngine [1.2.0.211,]
2020-03-26 18:42:32,743 [11] DEBUG DependencyAnalyzer - Orion.ESI [1.2.0.314,]
2020-03-26 18:42:32,744 [11] WARN DependencyAnalyzer - No packages of type Orion.ESI found!!!
2020-03-26 18:42:32,745 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.ESI [1.2.0.314,]
2020-03-26 18:42:32,746 [11] DEBUG DependencyAnalyzer - Orion.SSH [1.0.1.325,]
2020-03-26 18:42:32,747 [11] WARN DependencyAnalyzer - No packages of type Orion.SSH found!!!
2020-03-26 18:42:32,747 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.SSH [1.0.1.325,]
2020-03-26 18:42:32,748 [11] DEBUG DependencyAnalyzer - Orion.Apollo.PerfStack [2.2.0.679,]
2020-03-26 18:42:32,749 [11] WARN DependencyAnalyzer - No packages of type Orion.Apollo.PerfStack found!!!
2020-03-26 18:42:32,750 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.Apollo.PerfStack [2.2.0.679,]
2020-03-26 18:42:32,751 [11] DEBUG DependencyAnalyzer - Orion.CortexIntegration [2.0.0.2120,]
2020-03-26 18:42:32,752 [11] WARN DependencyAnalyzer - No packages of type Orion.CortexIntegration found!!!
2020-03-26 18:42:32,753 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.CortexIntegration [2.0.0.2120,]
2020-03-26 18:42:32,753 [11] DEBUG DependencyAnalyzer - SolarWinds.CortexPlugin.Orion.Volumes [2.0.0.254,]
2020-03-26 18:42:32,754 [11] WARN DependencyAnalyzer - No packages of type SolarWinds.CortexPlugin.Orion.Volumes found!!!
2020-03-26 18:42:32,755 [11] ERROR DependencyAnalyzer - No packages are matching constraint SolarWinds.CortexPlugin.Orion.Volumes [2.0.0.254,]
2020-03-26 18:42:32,756 [11] DEBUG DependencyAnalyzer - SolarWinds.CortexPlugin.Orion.Nodes [2.0.0.891,]
2020-03-26 18:42:32,757 [11] WARN DependencyAnalyzer - No packages of type SolarWinds.CortexPlugin.Orion.Nodes found!!!
2020-03-26 18:42:32,757 [11] ERROR DependencyAnalyzer - No packages are matching constraint SolarWinds.CortexPlugin.Orion.Nodes [2.0.0.891,]
2020-03-26 18:42:32,758 [11] DEBUG DependencyAnalyzer - Orion.Apollo.NetworkAtlas [1.0.0.0,]
2020-03-26 18:42:32,759 [11] WARN DependencyAnalyzer - No packages of type Orion.Apollo.NetworkAtlas found!!!
2020-03-26 18:42:32,760 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.Apollo.NetworkAtlas [1.0.0.0,]
2020-03-26 18:42:32,761 [11] DEBUG DependencyAnalyzer - Orion.Topology [2018.2.0.0,]
2020-03-26 18:42:32,762 [11] WARN DependencyAnalyzer - No packages of type Orion.Topology found!!!
2020-03-26 18:42:32,762 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.Topology [2018.2.0.0,]
2020-03-26 18:42:32,763 [11] DEBUG DependencyAnalyzer - Orion.Maps [1.0.0.0,]
2020-03-26 18:42:32,764 [11] WARN DependencyAnalyzer - No packages of type Orion.Maps found!!!
2020-03-26 18:42:32,765 [11] ERROR DependencyAnalyzer - No packages are matching constraint Orion.Maps [1.0.0.0,]
2020-03-26 18:42:32,766 [11] INFO DependencyAnalyzer - Looking for a valid package combination using method: ORToolsResolutionStrategy
2020-03-26 18:42:33,019 [11] WARN DependencyAnalyzer - Failed to found a suitable package combination using method: ORToolsResolutionStrategy
2020-03-26 18:42:33,020 [11] INFO DependencyAnalyzer - Looking for a valid package combination using method: BasicDependencyResolutionStrategy
2020-03-26 18:42:33,023 [11] INFO BasicDependencyResolutionStrategy - Evaluating all possible combination of packages for current system according to defined roots.
2020-03-26 18:42:33,065 [11] DEBUG BasicDependencyResolutionStrategy - Found 0 valid walks.
2020-03-26 18:42:33,065 [11] INFO BasicDependencyResolutionStrategy - Looking for best package combination.
2020-03-26 18:42:33,069 [11] DEBUG BasicPackageSetSelector - Searching for best package ...
2020-03-26 18:42:33,072 [11] DEBUG BasicPackageSetSelector - Number of sets: 0
2020-03-26 18:42:33,073 [11] DEBUG BasicPackageSetSelector - Removing sets where are packages without sources
2020-03-26 18:42:33,080 [11] DEBUG BasicPackageSetSelector - Number of sets: 0
2020-03-26 18:42:33,081 [11] WARN BasicDependencyResolutionStrategy - No valid solution found
2020-03-26 18:42:33,083 [11] WARN DependencyAnalyzer - Failed to found a suitable package combination using method: BasicDependencyResolutionStrategy
2020-03-26 18:42:33,083 [11] WARN DependencyAnalyzer - Failed to found a suitable package combination using all available methods.
2020-03-26 18:42:33,084 [11] ERROR PackageManager - Cannot find no valid combination for current system.
2020-03-26 18:42:33,086 [11] ERROR ConfigurationProgressScene - Exception while configuring plugins.
System.Exception: No valid package combination was found for current system.
