cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 12
Network Atlas could not be installed
We try to install Network Atlas on a Windows 7 64bits workstation but as soon as we launch the installer it stopped and display nothing at all.
Have you already seen this on your machine ?
There is an error : 1033 in the event log with a "success or error status 1624", hope this could help to find the issue.
Cheers
Labels (1)
0 Kudos
Level 12
A quick answer to myself. i have been able to install the Network Atlas from a share folder on the server. I have launch the msi from an explorer \\ip_address\c$\ProgramData\Solarwinds\Installers\SolarWinds-Orion-NetworkAtlas.msi.
That works fine, however the downloaded version from the link under a map is not functional at all.
That's a strange behavior...
0 Kudos
thanks a lot for that tip.
It helped me also on Windows 10.
Somehow the from the Map doesn't work....
0 Kudos
