Hello,
I have a map created with nodes and most of the connections are able to be set via ConnectNow, but there are a few that do not connect via ConnectNow (L2 & 3). These connections pass traffic, but did not connect via ConnectNow and I manually added them.
I looked at the connections on the map, and those that have defined connections usually have an Interface Index identified at least on one side.
Do you need the Interface Index identified on at least one side in order for the connections to function on the map?
Thank you for your time.
Ken
