Needed - UPS Universal Device Poller Status values for all UPS listed in a single report
I am trying to create a report that shows the values from the Universal Device Poller Status for each of our UPS. We want to use the report to plan battery replacements, firmware upgrades, etc. Additionally we would like to see if we are polling for each UPS without having to drill down to the Node Detail Summary for each device/node.
  • Create report and use the advanced database query for the selection method. I have put the query I use for an asset report below. It doesn't grab all of the Custom Pollers you would want so you can either create a new report for each poller or do some fancy SQL that I had to have one of our DBAs make to condense the multiple rows into columns (I had to do it for Asset info on our thin APs).  I might be able to figure out what my DBA did in the second query, but I would be guessing a lot. Well after you have the query you just add fields you want in the report table. Hopes this helped or that someone else has a better solution.
    UPS ASSET SQL Query
         SELECT DISTINCT
         CustomPollerAssignmentView.CustomPollerAssignmentID AS NetObjectID,
         CustomPollerAssignmentView.NodeID,
         CustomPollerAssignmentView.AssignmentName AS Name,
         CustomPollerStatus.Status AS Serial_Number,
         CustomPollerStatus.RowID,
         NodesData.IP_Address,
         NodesData.Caption,
         NodesData.Vendor,
         NodesData.IOSVersion AS Firmware_Version,
         NodesData.Status,
         NodesData.MachineType,
         NodesCustomProperties.County,
         NodesCustomProperties.Site_Type,
         NodesCustomProperties.Service_Owner
         FROM
         (CustomPollerStatus INNER JOIN CustomPollerAssignmentView ON
         (CustomPollerStatus.CustomPollerAssignmentID = CustomPollerAssignmentView.CustomPollerAssignmentID))
         LEFT OUTER JOIN CustomPollers ON
         (CustomPollerAssignmentView.CustomPollerID = CustomPollers.CustomPollerID)
         RIGHT JOIN NodesData ON
          (CustomPollerAssignmentView.NodeID = NodesData.NodeID)
         RIGHT JOIN NodesCustomProperties ON
          (CustomPollerAssignmentView.NodeID = NodesCustomProperties.NodeID)
         WHERE
           (NodesData.Vendor = 'American Power Conversion Corp.') AND
           (CustomPollers.UniqueName = 'upsAdvIdentSerialNumber')
    Thin AP SQL Query
         --Run this query on S200SOLWINDSQL: [SolarWindsOrion] database
         IF OBJECT_ID('tempdb..#Temp') IS NOT NULL
         BEGIN
             DROP TABLE #Temp
         END
         --Selecting all the data from the select query into a Temptable #Temp
         SELECT *
         INTO #Temp
         FROM
         SELECT DISTINCT
         CustomPollerAssignmentView.AssignmentName,
         CustomPollerStatus.Status,
         NodesData.Caption AS Controller_Name,
         NodesData.Vendor,
         NodesData.MachineType AS Controller_Model,
         FROM
         WHERE
           (NodesData.MachineType = 'Cisco 5500 Series Wireless Controller')
         )) AS TEMP
         --Creating another Temptable #Temp2 to Insert the required columns in a desired way
         IF OBJECT_ID('tempdb..#Temp2') IS NOT NULL
         BEGIN
             DROP TABLE #Temp2
         END
         create table #temp2
             AssignmentName nvarchar(100),
           [Status] [nvarchar](100) NULL,
           [RowID] [varchar](100) NULL,
           [IP_Address] [nvarchar](50) NULL
         insert into #temp2
         (AssignmentName,status,RowID,IP_Address) select SUBSTRING(LTRIM(RTRIM(AssignmentName)),1,CHARINDEX(' ',LTRIM(RTRIM(AssignmentName)))-1), Status, RowID, IP_Address
         from #Temp
         --Selecting the data required using PIVOT(Convert Rows to columns using 'Pivot')
         SELECT bsnAPSerialNumber,bsnAPName, bsnApIpAddress,bsnAPLocation,bsnAPIOSVersion,bsnAPModel,RowID, IP_Address from
         Select * from #temp2) As BaseData
         PIVOT (
                 max(Status)
           For AssignmentName
           IN([bsnAPSerialNumber],[bsnAPName],[bsnApIpAddress],[bsnAPLocation],[bsnAPIOSVersion],[bsnAPModel])
         AS PivotTable
          --For specific RowID results, use where clause
         --WHERE
         --ROWID='0.38.11.201.110.0'
  • Thanks! That got me in the right direction.
    This is the query that I ended up coming up with:
         BEGIN
             DROP TABLE #TEMP
         END
    SELECT *
         INTO #TEMP
         FROM
    SELECT
         NodesData.Caption AS 'Device',
      NodesData.IP_Address AS 'IP',
      CustomPollerAssignmentView.CustomPollerName,
      CustomPollerAssignmentView.CurrentValue
    FROM CustomPollerStatus
    ON (CustomPollerStatus.CustomPollerAssignmentID = CustomPollerAssignmentView.CustomPollerAssignmentID)
    ON (CustomPollerAssignmentView.CustomPollerID = CustomPollers.CustomPollerID)
    ON (CustomPollerAssignmentView.NodeID = NodesData.NodeID)
    WHERE NodesData.MachineType = 'SMARTUPS2') AS TEMP
    SELECT Device, IP,
    [upsBasicOutputStatus] AS Status,
    [upsAdvIdentSerialNumber] AS Serial_Num,
    [upsAdvIdentFirmwareRevision] AS Firmware,
    [upsAdvIdentDateOfManufacture] AS Mfr_Date,
    [upsAdvBatteryTempFahrenheit] AS Bat_Temp,
    [upsBasicBatteryTimeOnBattery] AS Bat_Time_On,
    [upsAdvBatteryRunTimeRemaining] AS Bat_Time_Remain,
    [upsAdvBatteryNumOfBattPacks] AS Bat_Packs,
    [upsAdvBatteryNumOfBadBattPacks] AS Bat_Packs_Bad,
    [upsAdvBatteryReplaceIndicator] AS Bat_Replace,
    [upsBasicBatteryLastReplaceDate] AS Bat_Replace_Date,
    [upsAdvOutputVoltage] AS Volt_Out,
    [upsAdvOutputCurrent] AS Current_Out,
    [upsAdvOutputLoad] AS Load,
    [upsAdvInputMinLineVoltage] AS Min_Volt,
    [upsAdvInputMaxLineVoltage] AS Max_Volt
    FROM (SELECT CurrentValue, CustomPollerName, IP, Device
          FROM #TEMP) p
    PIVOT
    MAX (CurrentValue)
    FOR CustomPollerName IN
    ([upsBasicOutputStatus],
    [upsAdvIdentSerialNumber],
    [upsAdvIdentFirmwareRevision],
    [upsAdvIdentDateOfManufacture],
    [upsAdvBatteryTempFahrenheit],
    [upsBasicBatteryTimeOnBattery],
    [upsAdvBatteryRunTimeRemaining],
    [upsAdvBatteryNumOfBattPacks],
    [upsAdvBatteryNumOfBadBattPacks],
    [upsAdvBatteryReplaceIndicator],
    [upsBasicBatteryLastReplaceDate],
    [upsAdvOutputVoltage],
    [upsAdvOutputCurrent],
    [upsAdvOutputLoad],
    [upsAdvInputMinLineVoltage],
    [upsAdvInputMaxLineVoltage])) AS pvt
    ORDER BY pvt.Device, IP
    DROP TABLE #TEMP
