cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Need help to generate report in Excel Format.
I am trying to generate scheduled report for Server availability in excel/CSV format.
Able to create scheduled report but received email with below error.
"Unable to retrieve url: https://url:443/Orion/Report.aspx?ReportID=228 using CSV type".
There is no error while selecting pdf as preferred format.
Please guide me to solve this issue.
Regards
Sunil
0 Kudos
1 Reply
CSV format is only supported if your report contains tables. Check this link: https://support.solarwinds.com/Success_Center/Network_Performance_Monitor_(NPM)/Knowledgebase_Articl...
- David Smith
