cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 12
NPM and VMAN question
So long story short 🙂 really its never short
So I have both NPM and VM integrated and its lovely 🙂
New Servers get spun up with in the Virtual environment so they show technically with in Virtualization summary but are really not managed nodes with in Orion. I tend to get a email ( sometimes ) from the server teams that a new server is up and running asking me to add it  but sometimes I stumble across them as bounce around NPM.
Question:  Is there a report or something i can set up to show me whats not managed in orion , maybe i missing it ? and how do other people deal with this as it drives me crazy ?
Steve
Labels (2)
0 Kudos
1 Reply
Level 17
‌the object type of vms that were disovered in vman should be vNodes. You can try to build a custom table based report that shows all the vnodes. Im not sure if it will exclude orion nodes automatically but that can be sorted with custom sql / swql. but that is where i would start
0 Kudos
