Does Solarwinds ORION NPM monitor computer desktops other than the usual network devices like switches and routers? Will it be able to RDP( I mean access remotely) to those monitored desktops?
Aaron
Aaron
You can monitor desktops as long as its got SNMP configured you can do the same as you would with a server.
We monitor half a dozen desktops and it works really well with NPM, clicking on the RDP link on the node page runs rdp client for remote connections.
HTH
Jon
