Dear All,
As you must be aware Metro Ethernet links are terminated on Ethernet port of router, but the actual bandwidth allocated by the service provider would be lesser then the interface bandwidth of 100Mbps. As in out case though the link is terminated on 100Mbps Ethernet port but the actual capacity of the link is 2Mbps.
So we edited the bandwidth capacity using interface property in the Orion device configuration menu to reflect 2Mbps. Now the graph shows link capacity as 2Mbps but the Percentage utilization graph shows utilization exceeding 1600%. Even the Mbps graph shows traffic exceeding 2Mbps mark.
Kindly advise if there is any other configuration to be done so that the graph shows proper utilization and doesn’t exceed the bandwidth capacity of the link.
Thanks & Regards
Vinod Dhure.
