Has anyone done any monitoring of their Cisco Wireless using SW vs. the WCS?
Being asked to evaluate it but not sure it will buy us anything.
CM
Do you currently own WCS? Do you have other wireless vendors in your environment? Orion will cover off the monitoring use cases and putting in a single view with you wired infrastructure.
WCS will help you with the more advanced use cases for wireless monitoring like heat maps.
