cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Modifying node and interface pollers
Hello,
I have currently built a poller for some of our Adtran Devices, and I was wondering if there was a way to change what the fields are called in the poller? Currently I have the description field polling the serial number field and would like to either change description to say serial number or add serial number in addition to description.
Also when the nodes interfaces are being polled. How can I determine what OID is polled for the Interface name? Currently it is grabbing an OID that has a bunch of extra information in it. I would like it to just pull the OID that reports "eth 0/1" and then the alias field. I have run an SNMP walk and found the OID that I need but unsure how to change it. Also will this change the OID that is polled on these specific devices or all interfaces across all devices?
I have attached a couple of images for reference.
Thanks for any help that can be provided.
Labels (2)
0 Kudos
