cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
Modification in Report Required ! Please Help
Hi All !
I am using mute alert report that is written in SWQL. (Pasting the code below).
My requirement is that we should have a comment field (lets say i can request users to write that in Notes field why did they put it in mute alerts). And then the notes field is also displayed as additional column.
Currently the code is below (please help to ammend this) so that notes field is added at the end.
SELECT EntityUri, UtcSuppressFrom, UtcSuppressUntil, LocalSuppressFrom, LocalSuppressUntil, Element, DetailsUrl, AE2.AccountID
FROM
SELECT DISTINCT [EntityUri],
[SuppressFrom] AS [UtcSuppressFrom],
[SuppressUntil] AS [UtcSuppressUntil],
ToLocal([SuppressFrom]) AS [LocalSuppressFrom],
ToLocal([SuppressUntil]) AS [LocalSuppressUntil],
CASE
WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%' AND [EntityUri] NOT LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/%'
THEN [N].[Caption]
WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Interfaces/InterfaceID=%'
THEN [I].[FullName]
WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Applications/ApplicationID=%'
THEN [AA].[FullyQualifiedName]
ELSE 'SomethingElse'
END AS [Element],
CASE
THEN [N].[DetailsUrl]
THEN [I].[DetailsUrl]
THEN [AA].[DetailsUrl]
ELSE '<a href="https://thwack.solarwinds.com/Orion/SummaryView.aspx">SomethingElse</a>'
END AS [DetailsUrl]
FROM Orion.AlertSuppression AS [AlertSup]
LEFT OUTER JOIN Orion.Nodes AS [N]
ON [AlertSup].[EntityUri] = [N].[Uri]
LEFT OUTER JOIN Orion.NPM.Interfaces AS [I]
ON [AlertSup].[EntityUri] = [I].[Uri]
LEFT OUTER JOIN Orion.APM.Application AS [AA]
ON [AlertSup].[EntityUri] = [AA].[Uri]
LEFT OUTER JOIN Orion.AuditingEvents AS [AE]
ON [AE].AuditEventMessage LIKE CONCAT('%', CASE
THEN [N].[NodeName]
THEN [I].[InterfaceCaption]
THEN [AA].[Name]
ELSE 'Wrong'
END, '%') AND [EntityUri] LIKE CONCAT('%=', [AE].NetObjectID)
INNER JOIN Orion.AuditingActionTypes AS [AT]
ON [AE].ActionTypeID = [AT].ActionTypeID
WHERE [AT].ActionTypeDisplayName LIKE '%mute%'
) AS tbl1
JOIN
SELECT NetObjectID, MAX(TimeLoggedUtc) AS MaxTimeLoggedUtc
FROM Orion.AuditingEvents AS AE
GROUP BY NetObjectID
) AS tbl2 ON tbl1.EntityUri LIKE CONCAT('%=', tbl2.NetObjectID)
JOIN Orion.AuditingEvents AS AE2 ON tbl2.NetObjectID = AE2.NetObjectID AND tbl2.MaxTimeLoggedUtc = AE2.TimeLoggedUtc
Tags (1)
0 Kudos
