Our setup is :
Orion
2018.2
NPM 12.3
SAM 6.6.1
I’m using 3
level nested map to aggregate into a single map all our site’s buildings and
computer rooms.
The lower
level maps are basically computer rooms containing nodes with their child item
status.
The middle
level maps are buildings containing computer rooms.
The upper
map is the whole site and contains the middle level maps.
Status
rollup mode & Child status rollup mode are set to “Show Worst status”
Here is the
issue:
A node has
minor child item issue, it shows node status = Green ; Child Item status =
Yellow within its low level map but the map itself appears Green/Green in the
middle level map and so on for the upper level map.
I expected
to have the Yellow child item status propagated from the node to the middle map
and then to the upper map but the upper map is green/green which doesn’t
reflect the real status.
Is it
expected behavior?
Thank you.
Best
Regards
