cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 9
Map Object Icons problems in the Orion Web Console
Jump to solution
Hello:
I have a big problem with the Map Objects Icons that I create in the Network Atlas Software. Any Map Object Icon (default or custom) that I create , it shows in the Network Atlas but it doesnt in the Orion Web Console. I did everything, since look for the folders when the images are located and all the steps for example; I did the "Changing the Appearance of Map Objects" help guide, "Adding Custom Icons from Graphics Files" help guide, "Adding Map Objects" help guide, "Pasting Custom Icons from the Windows Clipboard" help guide,I didnt find anything in the forum. The weird part is that I all the background images that I load in the Orion Network Atlas, it appears in the Orion Web Console, but that not happen with the Map Object Icons. I am attaching a example of that, it only appears a gray point in the Orion Web Console, instead the real icon.
Tags (4)
1 Solution
Level 9
Yes stormblade, I still have the problem anyone can help us, please, thanks
0 Kudos
Level 8
Here are the steps support gave me when I had a similar issue with maps not displaying any graphics/icons:
On the Main Orion server,
Browse to the Network Atlas installation folder:
<Volume>:\Program Files (x86)\SolarWinds\Network Atlas\Maps
Copy the following folder:
LEDS,
MapStyles
NetObjects
Overlays
To the following folder.
C:\Program Files (x86)\SolarWinds\Network Atlas\MapsWeb
** If folder MapsWeb does not exist, please create it manually.
I want to know that if the SolarWinds Orion NPM is installed on drive D instead, then the destination drive for copied file should hosted on drive C or D?
0 Kudos
I had this issue after reinstall Network Atlas. Thanks for sharing the solution. It worked like a charm.
0 Kudos
I was with this error
0 Kudos
Yes it works, thanks a lot I was waiting for long 8 months.
THANK YOU SO MUCH
0 Kudos
Level 9
0 Kudos
Level 7
I am hoping that this gets bumped and some folks have an answer.
My system is experiencing the same symptoms.
Atlas shows everything is created and saved properly, but all the icons are gray in the Orion map.
0 Kudos
