cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 10
Interface Details and changing resources
On my Interface Details view, I have the built-in "Min/Max/Average bits per second - Today" resource at the top of the right hand column.  However, it keeps modifying itself to use "Last 12 Months" as it's time frame.  I remove the resource, re-add it, and it's fine for a little while, then eventually it goes back to a 12 month view.  Any guesses on what's happening?
0 Kudos
Product Manager
Product Manager
Are you going in and editing the chart time period for any interface in Orion?  Does anyone else have your login that may be changing this?
0 Kudos
I'm not even aware of any way of editing the time period on that resource permanantly, and yes - in that order.
0 Kudos
Drill down to an interface and for that resource in the drop-down select "Edit Chart" and there you can select the time period
0 Kudos
Aha!  I had tried that, but was hitting refresh, not submit.
I'll check around for the culprit.
Thanks!
0 Kudos
