cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Installation issues
I have installed orion network performance monitor SLX. When I run the configuration wizzard for the first time, I get a "Runtime Error"
Runtime error 2147319779
Automation Error
Library not rgistered
Does any one know how to solve this problem? i have tried to uninstall and reinstall the program, but that does not help.
thanks
0 Kudos
1 Reply
Level 7
There is a couple things you could try. First, make sure you have a useable SQL server installed. Second, try registering the SolarWinds SQL object. Solarwinds walked me through it once. Just launch a dos prompt and CD to the SolarWinds/Network Performance Monitor V6 folder. Then type regsvr32 sqldmo.dll. Then try the Config Wizard again.
0 Kudos
