The compatibility page shows that I need to go to 10.7 first. Where can I download the 10.7 release?
Customer Portal Login | SolarWinds
You can download any previous version from there. First pick NPM, then use the drop-down to change the version from 11.5
In the customer portal when you goto my downloads you can use pulldown to select which product you want to download... after that right next to the product is another pulldown where you can select any of the versions if you are under maintenance.
I share the other users sentiments...
Our upgrade from 11.0.1 to 11.5 was a disaster. It has had us completely down and flying blind for many days, and we are still dealing with major performance issues now two weeks later.
You probably want to wait a few weeks/months for the dust to settle.
