Use the below step that will help you - i used same is working fine
- Save a copy of the original SolarWinds.Interfaces.Collector.dll.config file to your local drive as a backup file, in case you need to roll back later.
- SolarWinds strongly recommends that you only edit the SolarWinds.Interfaces.Collector.dll.config file as instructed. Any additional modifications may result in system performance issues or may create an error state.
- 1. Log in to your Orion server.
- 2. Go to C:\Program Files(x86)\SolarWinds\Orion\Interfaces\
- 3. Open SolarWinds.Interfaces.Collector.dll.config in a text editor.
- 4. Replace the following line:
<add key="ValidateCounters" value="True" />
with
<add key="ValidateCounters" value="False" />
- Restart SolarWinds services. Refer to Start and stop Orion services.
Note - Same step you should apply on all additional poller including the additional web server.
