cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
How to gather "show tech" info from Cisco switch based on threshold
Jump to solution
_alHello All,
I'm trying to find a way to gather "show tech" info from a group of Cisco switches once they reach a certain cpu utilization threshold. I know I can set up an advanced alert in NPM, and select a Triggered Action-->External Program, but I'm not that handy with writing scripts. Is there a simpler way to do this with NPM and NCM?
We have Catalyst 4500 model switches that randomly have very high cpu conditions that only clear with a reboot, so we are trying to capture the state of the switch ("show tech" output) when the condition occurs.
Thanks!
DW
0 Kudos
1 Solution
Dave,
I think you are correct there -- once you install NCM you'll have the option:
0 Kudos
Level 13
Hi DW,
Just a sidenote here --  you should keep in mind that running show-tech is a CPU intensive process, so running this while your CPU is pegged could potentially compound the issue.   I would pare it back a little and set your script to grab a copy of 'show proc' or 'show platform health' instead, but that's up to you.
As to how to do this, NPM has the option to execute an NCM action as a trigger action.  I think you just need to choose this item as your trigger action, then enter your config script elements and you should be set.
Good luck!
Brandon
Brandon,
I don't see "execute an NPM action" listed as an option, but I haven't installed NCM yet. Are you saying that I will have this as an option once NCM is installed? Thanks.
Dave
0 Kudos
Dave,
0 Kudos
Thanks Brandon! This is EXACTLY what I need! --Dave
0 Kudos
