History Wireless Clients SQL Query
I need to report on the Connected and Disconnected time for Wireless clients.
The History Wireless Clients resource displayed on Wireless This AP view shows me the exact details I am after, however, there is no comparable report that gives me the same details.
Does anyone (SolarWinds) know what query the History Wireless Clients resource is executing? If I have the query then I can create a Custom SQL report.
Thanks in advance.
  • Just to get the ball rolling, I've looked up the query being executed when loading the History Wireless Clients resource using SAM's AppInsight and this is what I get.
    (@nodeid int,@thinap bigint,@startPeriod datetime,@endPeriod datetime)SET TRANSACTION ISOLATION LEVEL READ COMMITTED;
    SELECT [T1].[C9] AS C1, DateAdd(second,DateDiff(second,GetUtcDate(),GetDate()),MIN([T1].[C10])) AS C2, DateAdd(second,DateDiff(second,GetUtcDate(),GetDate()),MAX([T1].[C11])) AS C3, MAX([T1].[C12]) AS C4, MAX([T1].[C13]) AS C5, SUM([T1].[C16]) AS C6, SUM([T1].[C15]) AS C7, AVG([T1].[C14]) AS C8
    FROM
    SELECT [T2].[MACAddress] AS C9, DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[FirstUpdate]) AS C10, DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[LastUpdate]) AS C11, [T2].[IPAddress] AS C12, [T2].[SSID] AS C13, ISNULL([T2].[SignalStrength],0) AS C14, ISNULL([T2].[InBytes],0) AS C15, ISNULL([T2].[OutBytes],0) AS C16
    FROM dbo.Wireless_ClientsHistory AS T2
    LEFT JOIN dbo.Wireless_InterfacesHistory AS T4 ON DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[LastUpdate]) = DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T4].[LastUpdate]) AND [T2].[ParentIndex] = [T4].[Index]
    LEFT JOIN dbo.Wireless_AccessPointsHistory AS T3 ON DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T4].[LastUpdate]) = DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T3].[LastUpdate]) AND [T4].[ParentIndex] = [T3].[Index]
    WHERE [T2].[NodeID] = @nodeid AND [T3].[Index] = @thinap AND ISNULL([T2].[MACAddress],'') <> ''
    ) AS T1
    WHERE [T1].[C11] >= @startPeriod AND [T1].[C11] <= @endPeriod OR [T1].[C10] >= @startPeriod AND [T1].[C10] <= @endPeriod OR [T1].[C10] < @startPeriod AND [T1].[C11] > @endPeriod
    GROUP BY [T1].[C9]
    ORDER BY [C3] DESC
    However, as I'm far from being a SQL guru, I don't know why I get a "This syntax is only allowed for parameterized queries" error when executing the query.
    Ideas?
  • I've changed your query little bit, I hope this is what you are looking fo. It's the same query we use for History Wireless Clients resource, but I've added extra columns with controller and AP name:
    DECLARE @startPeriod datetime
    DECLARE @endPeriod datetime
    SET @startPeriod='2013-10-29 23:00:00'
    SET @endPeriod='2013-10-30 09:43:45.830'
    SELECT [T1].[C18] AS Controller,[T1].[C17] AS APname,[T1].[C9] AS MACaddress, DateAdd(second,DateDiff(second,GetUtcDate(),GetDate()),MIN([T1].[C10])) AS Connected, DateAdd(second,DateDiff(second,GetUtcDate(),GetDate()),MAX([T1].[C11])) AS Disconnected, MAX([T1].[C12]) AS IPaddress, MAX([T1].[C13]) AS SSID, SUM([T1].[C16]) AS TransmittedBytes, SUM([T1].[C15]) AS ReceivedBytes, AVG([T1].[C14]) AS SignalStrength
    FROM
    SELECT [T6].[Name] AS C18, [T5].Name AS C17,[T2].[MACAddress] AS C9, DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[FirstUpdate]) AS C10, DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[LastUpdate]) AS C11, [T2].[IPAddress] AS C12, [T2].[SSID] AS C13, ISNULL([T2].[SignalStrength],0) AS C14, ISNULL([T2].[InBytes],0) AS C15, ISNULL([T2].[OutBytes],0) AS C16
    INNER JOIN dbo.Wireless_InterfacesHistory AS T4 ON DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[LastUpdate]) = DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T4].[LastUpdate]) AND [T2].[ParentIndex] = [T4].[Index]
    INNER JOIN dbo.Wireless_AccessPointsHistory AS T3 ON DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T4].[LastUpdate]) = DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T3].[LastUpdate]) AND [T4].[ParentIndex] = [T3].[Index]
    JOIN Wireless_AccessPoints AS T5 ON ([T5].[Index]=[T3].[Index] AND [T5].[NodeID]=[T2].[NodeID])
    LEFT JOIN Wireless_Controllers AS T6 ON ([T6].[ID]=[T5].[ParentID])
    WHERE ISNULL([T2].[MACAddress],'''') <> ''''
    AND (DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[LastUpdate]) >= @startPeriod
    AND DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[LastUpdate]) <= @endPeriod
    OR DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[FirstUpdate]) >= @startPeriod
    AND DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[FirstUpdate]) <= @endPeriod
    OR DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[FirstUpdate]) < @startPeriod
    AND DateAdd(second,DateDiff(second,GetDate(),GetUtcDate()),[T2].[LastUpdate]) > @endPeriod)
    ) AS T1
    GROUP BY [T1].[C18],[T1].[C17],[T1].[C9]
    ORDER BY 1,2,3 DESC
  • Excellent, thanks!
    This really should be a default report and or resource that can be added to a view.
    Regards,
    Deltona
  • Here is one more query, may be you will find it useful
    http://thwack.solarwinds.com/docs/DOC-171677
  • JiriPsota
    I am getting a notice in Configuration Wizard upon completion that this report was not converted. Any idea what changes between 10.4.x and 10.6.+ have caused this and what is needed to fix it?
  • I am not sure what you are talking about. Your SQL report is using new Wireless tables that were introduced in NPM 10.5, so it couldn't have worked before upgrade in NPM 10.4.x.
    Anyway, does it mean the report doesn't work for you now in NPM 10.6?
  • Sorry my bad. This report works just fine, I have misread the report name. It is the Wireless Session History custom report that couldn't be converted.
    I've recreated it and it works ok now.
