cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
Help! Manage Hardware Sensors is blank?
Somehow, the Manage Hardware Sensors page is completely blank. It used to have thousands of records. Any idea where they went?
Thank you.
0 Kudos
Level 8
Same issue here, a year later.....
0 Kudos
I'd suggest to restart all Orion services on Orion server (Programs > Solarwinds Orion > Orion Service Manager). If will not help then run Configuration Wizard for all items (database, website. services). If problem still exist then you have 2 options:
1. repair NPM installation from Control Panel > Uninstall Programs > Repair
2. assign case for SolarWinds Tech Support.
0 Kudos
