cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 13
Geist Environmental Monitor Temperature Displaying Incorrectly
I just added some more Geist Environmental Monitors to NPM and noticed that some of them are giving back crazy values.  I have confirmed that the MIBs listed on the Geist MIB list match with the temperature MIB that we have set in NPM.
Here is a screenshot of the resource.  73 and 78 are reporting the temperature correctly.
I was digging a little deeper and loaded up the UDP application and tried testing the MIB against some of the nodes that were and weren't reporting correctly.  When I tested the nodes with the crazy values, I got a "The OID is not supported" message.  I have checked and found that the firmware between working and non-working nodes is the same.  They are also the same model number.  Any ideas on what else I can do to check or how to get them to read the OID?
0 Kudos
Highlighted
Level 7
Re: Geist Environmental Monitor Temperature Displaying Incorrectly
We are just getting our geist into NPM and are not getting the temperatures to come through.  did you find anything out on this
0 Kudos
Highlighted
Level 13
I think it was that the MIBs that were in Solarwinds were incorrect for the current Geist version.  I did a MIBWalk on various Geist MIBs when I had one of the Geist's web front end up to compare the numbers I got back.
Here are some of the MIBs I'm using to pull back temps.  Hopefully this will help you get started.
AirTemp
MIB = 1.3.6.1.4.1.21239.2.5.1.6.1
Format = Enumeration
MIB Value Type = Raw Value
SNMP Get Type = GET
TempSensor
MIB = 1.3.6.1.4.1.21239.2.2.1.6.1
SNMP Get Type = GET
0 Kudos
Highlighted
Level 11
I'm using the 1.3.6.1.4.1.21239.2.2.1.6.1 OID, but I keep getting odd results.  If I SNMPwalk the device from my linux box it correctly reports 82.  If i use the snmpwalk.exe tool on the Orion server, it also correctly reports 82.  However, when I setup a graph for my Geists, all the other options (e.g. humidity, airflow, etc) are correct, but my temp is incorrectly reporting at 48.  I've got a ticket open to see what they say, but this makes no sense.
0 Kudos
Highlighted
Level 11
0 Kudos
