cancel
Showing results for
Search instead for
Did you mean:
deltabravo
Level 9
Don't monitor an interface until it is turned up
At my place of employment, our network engineers will have equipment installed before customer interfaces are connected.  The problem we have is that we will discover the node with solarwinds and all of the interfaces are admin up, oper down, until the customer connection is established.  I'd like a way to automatically disable alerts from these interfaces until a connection is established.  Is there a way to do this already?  Maybe a SQL query I can run to ignore down interfaces with 0% availability?
Labels (1)
0 Kudos
d09h
Level 16
Re: Don't monitor an interface until it is turned up
0 Kudos
orioncrack
Level 14
Alert on a custom property attached on only the interfaces you want to be bothered by.
We do this now and it works fine.
0 Kudos
deltabravo
Level 9
Well, this won't really work.  We can mute the alerts, but then we'd have to unmute them.  What we are wanting is for some type of "automatic in service" feature that will enable alerts only after the interface comes up initially.
0 Kudos
