I have several nodes for which I want to get interface bandwidth report. I don't want to get it for all nodes as that is very time consuming. How do I go about it?
Hi Ayesha,
if you have NPM 10.6 tehre is a new reporting on web. from there you may easily select the nodes that applies to your selection and report interface bandwidth just on them. use "data source" where you will define the nodes and then you may use custom table or custom chart (or both)
