cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 9
Custom Interface Bandwidth - 2 Mbps = 2000000 or 2048000 ?
Jump to solution
Hello,
I would like to know when I put a custom interface bandwidth what should I write in the boxes if I have a 2 Mbps ?
Should I write 2 000 000 or 2 048 000 ?
0 Kudos
1 Solution
Accepted Solutions
Highlighted
Level 12
Re: Custom Interface Bandwidth - 2 Mbps = 2000000 or 2048000 ?
Jump to solution
not sure if this will help but when you deal with Telephone Companies then it will always be set up as follows
T-1 = 1,544,000 or 1,536,000 depending on CSU overhead
E-1 = 2,048,000
but when using ethernet speed then it usually defaults back to true numbers where
2Mbps = 2,000,000
So depending on what you are monitoring will change what you should have in the field.
0 Kudos
Highlighted
Level 9
Jump to solution
Nobody uses this feature?
0 Kudos
Highlighted
Level 15
Jump to solution
Sounds like you're asking for the technical definition of Mbps. Based on various different sources, the answer would be 2 000 000, as you put it.
Highlighted
Level 9
Jump to solution
I probably confusing with the problem of data storage.
A megabit (mb) actually has two different values depending on what the term is being used to describe. When used to describe data storage, a megabit (mb) is the equivalent of 220 or 1,048,576 bits. However, when used to describe data transfer rates, one mb equals 1,000,000 bits.
Thanks for your links 😉
Highlighted
Level 12
Jump to solution
E-1 = 2,048,000
2Mbps = 2,000,000
0 Kudos
