Hi:
Please, is there any way to create a map without images or led´s ?
I only want this in the map:
Hi contracer,
You can create a custom report in the Orion report writer to display this information.
Then add the 'Report from Orion Report Writer' resource onto this page. Edit the new resource and select the report which you create in the report writer. This report will refresh each time page is loaded.
Another option is add the 'List Objects from Orion Map' resource to this page.
This allows you to list the objects on a map, and their status, without actually displaying the map.
