Convert BPS Output to Percentage of Interface Bandwidth
Hi there,
I'm using a slightly modified 95th percentile utilization rate report on specific interfaces.  The data output for the Interface is give in bps.  Is there a way to have this number converted to a percentage of the interface bandwidth as specified in solar.
For example, one of my interfaces shows a receive bps of 606Mbps.  The Interface bandwidth is 1000Mbps.  Is there a way to use the SQL code to convert this and generate a percentage of 60.6% ?
Here's the code
SET NOCOUNT OFF
SET ROWCOUNT 0
DECLARE @StartDate DateTime
DECLARE @EndDate DateTime
SET @StartDate = DATEADD(d, DATEDIFF(d, 0, DATEADD(m, -1, DATEADD(d, 1 - day(getdate()), getdate()))), 0)
SET @EndDate = DATEADD(ms, -2,DATEADD(d, DATEDIFF(d, 0, DATEADD(d, 1 - day(getdate()), getdate())), 0))
SELECT    Interfaces.InterfaceId,
        Nodes.NodeID,
        Nodes.Caption AS NodeName,
        Nodes.VendorIcon AS Vendor_Icon,
        Interfaces.Caption AS Interface_Caption,
        Interfaces.InterfaceIcon AS Interface_Icon,
        Maxbps_In95,
        Maxbps_Out95,
        Maxbps_95
FROM Nodes
INNER JOIN Interfaces ON Nodes.NodeID = Interfaces.NodeID
INNER JOIN (
    SELECT    InterfaceID,
            dbo.GetInBps95th(InterfaceID, @StartDate, @EndDate) AS Maxbps_In95,
            dbo.GetOutBps95th(InterfaceID, @StartDate, @EndDate) AS Maxbps_Out95,
            dbo.GetMaxBps95th(InterfaceID, @StartDate, @EndDate) AS Maxbps_95
    FROM InterfaceTraffic
    WHERE InterfaceTraffic.DateTime >= @StartDate AND InterfaceTraffic.DateTime <= @EndDate AND InterfaceID in (34567,29355,30320)
    GROUP BY InterfaceID
) TrafficStat
ON Interfaces.InterfaceID = TrafficStat.InterfaceID
WHERE ${LIMITATION}
ORDER BY NodeName, Interface_Caption
  • My DBA's figured it out... here is the correct code.
    SET NOCOUNT OFF
    SET ROWCOUNT 0
    SELECT Interfaces.InterfaceId            AS InterfaceID,
                  Nodes.NodeID                      AS NodeID,
                  Interfaces.InBandwidth            AS Interface_Bandwidth,
                  -- RAW NUMBERS
                  Maxbps_In95 / 1000000.0           AS Maxbps_In95,
                  Maxbps_Out95 / 1000000.0   AS Maxbps_Out95,
                  Maxbps_95 / 1000000.0             AS Maxbps_95,
                  -- PERCENT CALCULATION
                  Maxbps_In95 / Interfaces.InBandwidth  * 100     AS ReceivePCT,
                  Maxbps_Out95 / Interfaces.InBandwidth * 100     AS TransmitPCT,
                  Maxbps_95 / Interfaces.InBandwidth     * 100     AS MaxPCT
    FROM Nodes
    INNER JOIN (
           SELECT InterfaceID,
           WHERE
                         AND InterfaceID in (30167,
                               34395,
                               33765,
                               17950
    ) TrafficStat ON Interfaces.InterfaceID = TrafficStat.InterfaceID
    WHERE
           (1=1)
    ORDER BY
           NodeName,
           Interface_Caption
  • Hi Haydanb,
    Thanks mate for sharing the SQL Query. I am totally new to the SQL query but I have a similar requirement wherein I want to convert the avg and peak bps utilization in avg % and peak% (separate for In and Out, not a combine result).
    Please suggest if you can share some relevant query. I want an output in below form.
