cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 10
Changing the node status led with hardware health info
Is there a way to change the node status led, possibly keeping node status as it is but adding the small led (i.e. the one that is used for interfaces out of the box) in case of hardware health issues?
The idea is to make evident that there is an issue on the node even if the node is up and running.
0 Kudos
