I was wondering if anyone has had success in getting Orion to read Cisco devices in Fahrenheit instead of Celsius. Please share here if you have any info will help.
Bret
Hi kindbro,
UnDP does not read values as Celsius or Fahrenheit directly. It just reads value from provided OID and you can convert this value then. In fact, you will read some value as integer type and then you can decide what to do, if convert from Celsius to Fahrenheit or Bytes to MegaBytes or vice versa.
If you are asking for fucntion which converts Celsius to Fahrenheit, then create new transform poller and use CtoF () function with poller name in parenthesis.
Pavel
I've actually changed the poller that I'm converting to keep history so when the temp goes down again this evening, I'll hopefully be able to isolate the issue. We have a couple of Cisco Wireless Bridges out in Thorntown, IN. After the results this evening, I'll see if I need to proceed with putting in a support case. The OID is 1.3.6.1.4.1.9.9.13.1.3.1.3
