cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 11
Bootstrap no more - How to monitor Orion from outside of SolarWinds
We reacently had several stalls - object last poll and next poll times we old, data was not being collected, nodes were not being updated. I deveolped an external to SolarWinds monitor to alert me when the last update is over 15minutes behind now.:
I developed this query against the SW DB:
Select abs(datediff(MINUTE, TimeStamp, GETUTCDATE())) as 'SinceLastUpdate',
DATEADD(mi, DATEDIFF(mi, GETUTCDATE(), GETDATE()), timestamp) AS LastUpdate
from APM_CurrentApplicationStatus
join APM_Application app on app.id = APM_CurrentApplicationStatus.ApplicationID
where applicationid =19 -- My Orion SAM application is ID #19, pick something that works for you
order by LastUpdate
Once I verified this worked and returned correct information, in local time (will work where you are thanks to GETUTCDATE() ), I had a script made by our SCOM guy:
#===========     FUNCTIONS            ===========
Function EndScript
  $EventMessage = "End Script."
  Write-EventLog -LogName $LogName -EntryType $InfoLogType -EventId $InfoLogID -Source $EventSource -Message $EventMessage
  Exit
# Create necessary variables to use throughout the script
$ErrorActionPreference = "SilentlyContinue"
$WshShell = New-Object -ComObject "WScript.Shell"
$scriptName = $MyInvocation.MyCommand.Name
$strFilenameWithoutExtension = [System.IO.Path]::GetFileNameWithoutExtension($scriptName)
$LogName   = "Application"
$WarnLogType  = "Warning"
$InfoLogType  = "Information"
$ErrorLogType  = "Error"
$WarnLogID   = "650"
$InfoLogID   = "600"
$ErrorLogID  = "700"
$EventSource  = $strFilenameWithoutExtension
If (!(test-path HKLM:\SYSTEM\CurrentControlSet\Services\Eventlog\Application\$EventSource))
   new-eventlog -logname $LogName -source $EventSource
# Begin main code here
$user = "MsSQL_User"
$sqlUserPassword = "MsSQL_User's_Password_here"
$database = "SolarWinds_DB_Name"
$dataSource = "Database_with_instance"
$connectionstring = "Server=$dataSource;uid=$user;pwd=$sqlUserPassword;Database=$database;Integrated Security=False"
$connection = New-Object System.Data.SqlClient.SqlConnection
$connection.ConnectionString = $connectionstring
$connection.Open()
$query = "select abs(datediff(MINUTE, TimeStamp, GETUTCDATE())) as 'SinceLastUpdate', DATEADD(mi, DATEDIFF(mi, GETUTCDATE(), GETDATE()), timestamp) AS LastUpdate from APM_CurrentApplicationStatus where applicationid =19"
$command = $connection.CreateCommand()
$command.CommandText = $query
$result = $command.ExecuteReader()
$table = new-object “System.Data.DataTable”
$table.Load($result)
$format = @{Expression={$_.SinceLastUpdate};Label="SinceLastUpdate";width=10},@{Expression={$_.LastUpdate};Label="LastUpdate"; width=30}
[string]$MinSinceLastUpdate = $table | select SinceLastUpdate
[string]$LastUpdate = $table | select LastUpdate
$connection.Close()
$arrLastUpdate = $LastUpdate.Split("=")
$FinalResult_LastUpdate = $arrLastUpdate[1].Replace("}","")
$arrMinSinceLastUpdate = $MinSinceLastUpdate.Split("=")
[int]$FinalResult_MinSinceLastUpdate = $arrMinSinceLastUpdate[1].Replace("}","")
If ($FinalResult_MinSinceLastUpdate -gt 15)
  $command = "[Set a call here to your alerting system]-subject ""SolarWinds System Stall"" -message ""SolarWinds systems not updated for $FinalResult_MinSinceLastUpdate minutes . The last update was $FinalResult_LastUpdate"""
  #Write-Host $command
  Invoke-Expression $command
# End main code
I set a schedualed job to run every 15 minutes and now I am alerted if the system stalls!
Enjoy
Labels (1)
Tags (2)
1 Reply
I like everything about this - from the event log using your script name to the replace and split of the LastUpdate.
0 Kudos
