How is everyone doing this? Ideally, you'd want to monitor all of your interfaces, but not alarm on them if they're not in use. You can set the interface to admin down on the switch, and Orion then knows it's not down, but then if you use that interface in the future you will have to make sure it's checked in Orion for monitoring. This seems like an extra step, and can result in critical interfaces not being monitored if someone forgets or misses that step. Also to consider are ports that change dynamically (IE; a port a user is connected to goes down because they've shut off their computer). Is there a way to do this without the manual work of constantly unchecking/checking interfaces you care about?
