cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 10
Best way to monitor swicth ports
When I added my switches into solarwinds it shows the ports that are not hooked up as down. I found the setting to have them shown as unplugged but if I decided to plug them in one day I need to get an alert if that interface goes down. How can I not get alerts for ports that are unplugged but still get alerts if one goes down?
0 Kudos
Level 17
is administratively shutting the ports down not an option?
0 Kudos
Level 10
I would rather not. I'd like to be able to plug something into it without having to enable the port. I would like to be able to automate distinguishing between a down port and an unplugged port. Is there a way to do that?
0 Kudos
Level 11
I don't think you can have it both ways.  As long as you have that option set, if it goes down, it's going to go into "unplugged" status.
Here's what I have done, however this is for a scenario where I expect the port to be in use soon, and once it's in use I expect it to stay that way.
I set up an alert that only writes an NPM event when the port is unplugged (this should only happen once, right after you set it that way, but for some reason here it refires periodically).  Then I set the reset on that alert to send me an email when the port comes up.  That email is my cue to go back and change the interface settings to NOT show as unplugged anymore. I also have this event opening a ticket in our ticketing system, so I don't forget to make the settings change.
FWIW 🙂
0 Kudos
Level 10
that sounds like the best option. Where do I put in a feature request to solarwinds?
0 Kudos
Community Manager
Community Manager
You can submit a feature request for NPM here.
DH
0 Kudos
