cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 10
Application component details help
I am trying to extract a list of the configured applications and the details of the components with in those applications.
I can get the application name and component names, but I am having trouble figuring out the table that correlates the component details.
I want to retrieve the URL from HTTP or HTTPS component monitors, service names from service component monitors, and process names from process component monitors.
Can someone tell me what table to get this level of details from?
Here is the basic SWQL query that I have now:
SELECT C.ComponentID, C.ComponentName, A.Name AS ApplicationName, A.Status AS AppStatus, A.StatusDescription AS AppStatusDesc, N.Caption AS NodeName
FROM Orion.APM.Component C
INNER JOIN Orion.APM.Application A ON C.ApplicationID=A.ApplicationID
INNER JOIN Orion.Nodes N ON A.NodeID=N.NodeID
@aLTeReGo
0 Kudos
Everything goes from ComponentTemplateSetting unless you have any components where you hit the "override template" button.  I usually end up reporting on them by doing something like this
select top 20
n.caption
, a.name
, c.Name
, cts.key
, isnull(cs.Value,cts.Value) as value
, c.ComponentType
from orion.nodes n
join orion.apm.Application a on a.nodeid=n.nodeid
left join orion.apm.Component c on c.ApplicationID = a.ApplicationID
left join orion.apm.ComponentTemplateSetting cts on cts.ComponentTemplateID =c.TemplateID
left join orion.apm.ComponentSetting cs on cs.ComponentID=c.ComponentID and cs.key=cts.Key
where cts.key in ('Url')
- Marc Netterfield, Github
0 Kudos
Product Manager
Product Manager
You will find component settings, like the URL configured for a specific component, in the APM_ComponentDefinitionSetting table.
0 Kudos
@aLTeReGo
Thanks for the help.  It pointed me in the right direction.
I didn't have very many values in the Orion.APM.ComponentDefinitionSetting table.  I had to pull the URL details from the Orion.APM.ComponentTemplateSetting table.
