cancel
Showing results for
Search instead for
Did you mean:
Create Post
Any method for increasing intelligence of links in Network Atlas?
I'm pretty sure this isn't doable, but with such a robust community I thought I should ask first!
Is there any way to conditionalize the colors of links in Network Atlas map creation?
Right now, the link color turns red when a link is down.
What would be great is to figure out a way to, say, turn a link color amber between two sites if latency goes beyond a defined threshold.
Thanks for any information!
Labels (2)
Tags (1)
