Hi All,
I'm a newbee to Solarwinds, and looking for a little help.
Looking to create an alert that e-mails our team when a particular server (node) powers on.
The server is intended to be powered off because it has old certs, and not ready for decom.
I tried using to use the out of the box alert "Alert me when a group goes down" in reverse, but not getting the e-mails.
1) Do I need to create a monitor instead of an alert?
2) I've included the settings below, but not sure if this is my problem.
Any input is appreciated.
Name of alert:
Alert when RootCA is turned ON
Description of alert:
Node
Enabled(On/Off):
Evaluation Frequency of alert:
Severity of alert:
No Alert Custom Properties defined
Alert owner (user who created this alert):
Alert Limitation Category
Trigger Condition:
Alert on all objects where:
Node - Node Name - is equal to - AmyTestServer
The actual trigger condition:
Node - Status - is equal to - Up
Reset Condition:
When the trigger condition is no longer true
Time of Day schedule:
Trigger Action:
2. Send an Email/Page (ALERT: Node ${NodeName} is ${Status})
Reset Action:
Alert Integration
Alert integration with other SolarWinds Products | ||||||||||||||||||
When specific alert is triggered or reset, the other alert-managing products (e.g. ServiceNow Integration, AlertCentral, WebHelpDesk) can be informed about this event to take appropriate further steps.»What products can I integrate my alert with? | ||||||||||||||||||
Integrate alert with other SolarWinds products and subscribers (Recommended) | ||||||||||||||||||
Alert subject Use the name of alert as a subject Severity Properties to include
