Hi forum,
I has read solarwind document about managing dependency, I think the sense behind that is quite simple.
However when applying it in my system, it doesn't work. I create a simple case by creating a new alert to a specific node. Then I create dependency with the parent object as interface of up stream SW and the child object as the node which I created alert for. When I pretend to shutdown the interface, the alert for downstream node still fine and the Node status is down. The alert should not fine and the Node status should be unreachable.
Do I misunderstand the meaning of dependency, or make wrong configuration anywhere? Please point me out!
Thanks a lot!
