I am new to Orion so this is probably an easy question.
I wanted to monitor my switch interfaces for late collisions. So I setup a custom poller for it and assigned it to the one switch I have added to Orion so far. When I pull up the device view I see it on the device page and I see one of my interfaces is having late collisions and the numbers increase each polling cycle.
So I want to alert on this so I setup an Advanced alert with the following config
Poller Name is equal to dot3StateLateCollisions
Rate is grater then zero
and configured it to email on trigger (and tested email which worked).
I did enable the alert as well.
However, even though I see the LateCollisions increasing on device view, the alert is not triggering. What am I missing?
