cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Level 9
Re: 12.0.1 running out of memory
Jump to solution
We've now traced our memory leak to a rogue custom availabillty chart. The chart was showing availabiility over last 30 days for 8 nodes. It appears the chart was somehow corrupt as creating a new chart with the same data didn't trigger the memory leak. We found this by isolating different elements of a view we'd been working on and loading each one in turn until the memory started increasing significantly.
Interestingly, closing the page showing the chart didn't release the memory back that the information service had grabbed. Only way to do this was to kill the information service v3 and let it respawn.
Highlighted
Level 13
Jump to solution
Weirdly, after making a custom chart, I have the same problem. It spiked at 97%
I want to end the service and then restart and see it that resolves it.
Urgh - why does s**t have to be so complex sometimes.  I only want a b****y chart and it's gone insane and taking 14gb up.
0 Kudos
Highlighted
Level 14
Jump to solution
We have fixed a couple of memory leaks since 12.0.  The best bet is to install the latest Service Release and Hot Fixes.  If the issue continues, it's time to open a Support case and we'll dig in with you.
Highlighted
Level 14
Jump to solution
Experiencing this with 12.1.
0 Kudos
