cancel
Showing results for
Search instead for
Did you mean:
Create Post
NCM Not downloading full configuration [Case studies]
So in this case NCM failed to download the full configuration from the device.
How you troubleshot this ?
You must check  your Session Trace first to track the activity .
VIEW LIVE NCM logs NCM Connection profile test Compare Success and Failure and troubleshot understan...
Here is an example case: as you can see immediately after interface # NCM sent a command exit where its stopped downloading the configuration from the device.
Cause:
The issue is in that config line: description # Cisco ASA 5500 GAAE1/2 (Inside) #
Reason:
NCM have build-in logic to recognize config mode command prompt on devices.
That logic check if line ends with ‘)#’ or ‘) #’ and assume this is command mode prompt which mean end of config.
That is why NCM stop capture any config lines after that line.
Resolution:
To workaround this issue please modify that interface description line to not end with ‘) #’.
Looks like only that interface contains such unusual description.
That should resolve the issue
Version history
Revision #:
1 of 1
Last update:
‎11-06-2019 06:02 AM
Updated by:
