cancel
Showing results for
Search instead for
Did you mean:
Create Post
CSCO-ASA - Logging and NTP
Firewall Security Technical Implementation Guide - Cisco  Version: 8:  Release: 25:  26 Jan 2018
Thank you for choosing this document.  You will need to supply vendor specific CLI or Regular expression statements for these checks.
You will need to create TWO Custom Properties for your Devices.
Name the first column "C1_DeviceType" and include the following drop-down selections:
L2SW  -  Layer 2 Switches
IL3S  -  Infrastructure Layer 3 Switches
IRTR  -  Infrastructure Routers
PL3S  -  Perimeter Layer 3 Switches
PRTR  -  Perimeter Routers
XE    -  IOS-XE Routers
F5 - F5 Load Balancers
FW - Firewall SRG Devices
IPSEC - IPSEC VPN Devices
SRX - Juniper SRX Devices
IDPS - Intrusion Detection and Prevention Systems
Name the second custom property "C2_OS" and include the following drop-down selections:
OSXE  -  To support IOS and IOS-XE devices
NXOS  -  To support Nexus OS
ASA   -  To support ASA OS
IOSXE  -  To support IOS-XE Routers
F5 - To support F5 Big IP Load Balancers
FW - To support Firewall SRG devices
VPN - To support VPN specific STIGs
SRG - To support SRG Type Documentation
SRX - To support SRX Device Management
This file was uploaded from the "Shared on Thwack" Tab via NCM Compliance tree.
Thanks and stay tuned........
Labels (1)
Tags (1)
Version history
Revision #:
1 of 1
Last update:
‎02-27-2018 07:27 AM
Updated by:
