cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Level 7
problem to add a node from a perl script
I was able to delete a node, but I was not able to add a node.  I really don't know what wrong with my perl script is.
Please help.
Thanks in advance.
The script printed out "done", but I don't see the new node in NCM.
use SW::InformationService;
use SW::Orion;
use SOAP::Lite;
my $hostname = "localhost"; # fill in a hostname
my $username = "admin";
my $password = "abc";
my $endpoint = "https://$hostname:17778/SolarWinds/InformationService/v3/OrionBasic";
my $swis = SW::InformationService->new();
$swis->outputxml("true");
$swis->proxy($endpoint);
$swis->proxy->ssl_opts(verify_hostname => 0);
$swis->proxy->http_request->authorization_basic($username, $password);
my $ip = '10.10.10.10';
my $node_name='ten';
my $False='false';
my $True='true';
my $AddedNode = $swis->Create('Orion.Nodes',
    IPAddress=> $ip,
    IPAddressGUID=>ip2guid($ip),
    EntityType=>'Orion.Nodes',
    Caption=>$node_name,
    DynamicIP=>$False,
    EngineID=>$True,
    Status=>$True,
    UnManaged=>$False,
    Allow64BitCounters=>$True,
    External=>$False,
    ObjectSubType=>"SNMP",
    Community=>"public",
    SNMPVersion=>2,
    Comments=>"added by script",
print "\n done \n";
0 Kudos
