cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
juniper switch firmware upgrade using NCM
can we bulk upgrade juniper switch firmware using NCM? any experience and guidance would be definitely helpful, thanks
0 Kudos
Level 16
@aryal
Yes you can.
The out of the box one for j-routers is the same to any other JunOS device.
0 Kudos
When using ncm for upgrades, the process appears not to upload the Junos .tgz file to the system thus the upgrade is not working. in JUNOS you need issue the command > request system software add <location of file> yet it appears that this fails because there is no .tgz firmware file uploaded.  How to resolve this? samples?
If " Out of box" this should work, but does not
0 Kudos
