cisco cli script with 2 loop variables
Is it possible to do a script that outputs 2 looped variables with the below
i input 10,20 and data,voice and get
vlan 10
 name data
vlan 20
 name voice
The closest i have been able to come is the below
script ConfigureVLANCisco (
                                          NCM.Nodes @ContextNode,
                                          string [] @vlans,
                                          string [] @vlansname )
  CLI
   configure terminal
  foreach (@vlan in @vlans)
  foreach (@name in @vlansname)
    CLI
       vlan @vlan
         name
which outputs
vlan 10
 name data
 name voice
vlan 20
 name data
 name voice
any help is appreciated.
  • Hi
    If your VLAN IDs and names are static, just do:
      CLI
       configure terminal
      vlan 10
       name Data
       vlan 20
       name Voice
    If you want to be able modify VLAN ID and name, do this:
    .PARAMETER_LABEL @VLANid
    VLAN ID
    .PARAMETER_DESCRIPTION @VLANid
    What is the ID of the VLAN being created?.
    .PARAMETER_LABEL @VLANname
    VLAN Name
    .PARAMETER_DESCRIPTION @VLANname
    What is the name of the VLAN being created?.
    script UpdateTimeZoneCiscoIOS (
    int[] @VLANid,
    string @VLANname
    CLI {
    configure terminal
    vlan @VLANid
    name @VLANname
  • neither variable is static, i need both variables to be whatever the user inputs.  Also without a foreach loop in your script the variables just spit out
    System.Collections.Generic.List`1[System.String]
    so i updated the script to the below
    VLAN ID
    VLAN Name
    script CiscoIOS (
    int[] @VLANid,
    string[] @VLANname
    CLI
    configure terminal
    foreach (@vlan in @VLANid)
    foreach (@name in @VLANname)
    CLI {
    configure terminal
    vlan @vlan
    name
    and now the result is the below which is still not what i am looking for
    configure terminal
    vlan 10
      name data
    vlan 10
      name voice
    vlan 20
      name data
    vlan 20
      name voice
    again i want the user to input multiple items for 2 variables to output the below (input example is 10,20 and data,voice but these are not static can be any number and any string)
    vlan 10
     name data
    vlan 20
     name voice
