cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 7
Working WLC backups for NCM 6.1 and WLC 6.0.X
Anybody have a working script for NCM 6.1 and Cisco WLCs running 6.0.X or 7.0.X code?
Here's what I'm using today:
<Configuration-Management Device="Cisco WLC" SystemOID=" 1.3.6.1.4.1.9.1.828">
    <Commands>
        <Command Name="PreCommand" Value="${CRLF}"/>
              <Command Name="RESET" Value=""/>
        <Command Name="DownloadConfig" Value="show run-config"/>
        <Command Name="More" Value="Press Enter to continue Or &lt;Ctrl Z&gt; to abort"/>
    </Commands>
</Configuration-Management>
The issue I'm seeing is that the WLC appears to have two different "more" prompts.  Mid-config section the prompt is:
--More or (q)uit current module or <ctrl-z> to abort
At the end of each section, the prompt is:
Press Enter to continue or <ctrl-z> to abort
Enabling tracing shows this repeating over and over in the logs:
[5/4/2011 2:24:21 PM] TimerTick: mstrData=<> State=3 - Connected to server - idle
[5/4/2011 2:24:21 PM] Pending Disconnect = False
[5/4/2011 2:24:21 PM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[5/4/2011 2:24:21 PM] Config Prompt detector error: Invalid procedure call or argumentCurrentLine:
[5/4/2011 2:24:21 PM] Fuzzy match detector start detecting prompt. String1= String2=(ciscocontroller)>
[5/4/2011 2:24:21 PM] TimerTick: Just tick-tockin away. ..
Also seeing this same issue on our 4400s running 6.0.202 and a 5508 running 7.0.X.
Any suggestions or known working scripts?
0 Kudos
Highlighted
Level 7
Re: Working WLC backups for NCM 6.1 and WLC 6.0.X
I have the same issue. Anyone ever come up with a solution?
0 Kudos
Highlighted
Level 15
Have you tried playing with the  terminal length command in order to try to get rid of teh "more"?
On some devices, the syntax looks like this...  <Command Name="RESET" Value="terminal length 1000" />
0 Kudos
Highlighted
Level 10
TFTP is the only way to get this without --More-- Lines that I have come across, as there is not a way to turn off paging.(again from what I ahve been able to find)
Back up the Current WLC Template:
Replace the current WLC tempalte Commands with the following and set the transfer protocol to TFTP:
<Command Name="Reset" Value=""/>
            <Command Name="PreCommand" Value="y"/>
            <Command Name="MenuBased" Value="false"/>
            <Command Name="DownloadConfig" Value="show run-config commands"/>
            <Command Name="DownloadConfigIndirect" Value="transfer upload mode tftp${CRLF} transfer upload datatype config${CRLF} transfer upload filename ${StorageFilename}${CRLF} transfer upload serverip ${StorageAddress}${CRLF} transfer upload start${CRLF}y"/>
            <Command Name="More" Value=" or "/>
            <Command Name="Version" Value="show sysinfo"/>
Note: With this also the SSH ro Telnet will give an output as TFTP, but will still probably have a more lineor two.
0 Kudos
Highlighted
Level 7
We have been using the following WLC template by Jodros:
<!-- edited with Notepad by Jodros-->
<!--Copyright 2005 SolarWinds.Net All rights reserved-->
<Configuration-Management Device="Cisco WLC" SystemOID=" 1.3.6.1.4.1.14179.1.1.4.3">
 <Commands>
   <Command Name="DisablePaging" Value="config paging disable" Delay="300"/>
  <Command Name="Reboot" Value=""/>
  <Command Name="EnterConfigMode" Value=""/>
  <Command Name="ExitConfigMode" Value=""/>
  <Command Name="Startup" Value=""/>
  <Command Name="Running" Value=""/>
  <Command Name="UploadConfig" Value=""/>
  <Command Name="DownloadConfigIndirect" Value=""/>
  <Command Name="UploadConfigIndirect" Value=""/>
  <Command Name="EraseConfig" Value=""/>
  <Command Name="SaveConfig" Value=""/>
  <Command Name="Version" Value=""/>
  <Command Name="PreCommand" Value="${CRLF}" Delay="1"/>
  <Command Name="More" Value="(q)uit" Delay="1"/>
  <Command Name="VirtualPrompt" Value="(Cisco Controller) >"/>
 </Commands>
It is working great for our 6.0 WLCs.
0 Kudos
