cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
Shutdown Interface using NCM, Powershell or Python?
Jump to solution
Is there a way to shutdown an interface after a certain amount of time being down? I'm trying to create an alert that will email stating it is down (this part works) then the escalation portion will then run an ncm script or external script to shutdown the interface. Is this possible?
1 Solution
It is not clear if you have the time period covered, but this will simply be part of the trigger filter using the 'Last Status Change' value.
Make sure in the Alert Object setting on Trigger tab you select Interface, so that the Interface variables are available to pass to the Execute NCM Action.
Write out your command to shut the interface eg.
conf t
interface ${N=SwisEntity;M=InterfaceName}
shut
end
Copy run start
conf t
shut
end
Copy run start
Hi m_roberts
Could that action "be vendor agnostic" ?
Cisco/Juniper/HP...
0 Kudos
Yes, that is the beauty of NCM, in that the Execute Script function in the alert is simply a box you can type out the appropriate command syntax for the device you are applying the change to.
Therefore, when you are creating your alert, you may have an alert definition for devices that support Cisco IOS commands within the action of the alert and then a separate alert which will have the syntax for Junos. Each alert will simply need a filter on the Trigger Filter page so that the specific vendors are included only to match the alert action definition.
0 Kudos
This works, thank you Mark!
